Re: Puch E50 case prep for new build
Overpriced Parts /
Make sure you don’t get the semi dryIng sealer in the oil hole for the bearing when you put the case halves together
I’ve seen that mistake several times, oozing from too much blocks oil hole in case on mag side the bearing goes away real quick
