Re: Puch E50 case prep for new build
Papa _ /
> Overpriced Parts Wrote:
> Make sure you don’t get the semi dryIng sealer in the oil hole for the
> bearing when you put the case halves together
> I’ve seen that mistake several times, oozing from too much blocks oil
> hole in case on mag side the bearing goes away real quick
The engine I’ve got right now had a lip or ridge from casting around that oil hole. I’m assuming when you said you filed sharp edges, you would have got that as well. It’s something else to look for. Pretty simple engine. Not a whole lot else you could do or have to worry about.
