Kinetic TFR won't take the gas
Larry Humpolick /
Help!!!
Installed a BBK on this unit and spring loaded float needle it runs but will not stay running unless i keep the choke on after 2 months i'am getting a little tired of this.
Any ideas?
Please help
Larry
Re: Kinetic TFR won't take the gas
Did you up jet?
TOP GUN™ ANDY ⚔ (LSLB) ⚔ /
you have an air leak, or you are too lean on the jet
Larry Humpolick /
Up jet? Did not know that the parts source did not mention that I tightened every nut screw I could find I did replace the fule tank because the inside frame was rotted out New spark plug, replace the coil because of no spark. I am this close to getting this on the road.
Thank you for all your help on this.
Larry
