Tomos mags on a Garelli?
Anyone ever swap a set of Tomos Grimeca mags onto a garelli? Swapped the tire around to the other direction, rear sprocket fits perfectly, the only issue I’m running into is the brake assembly.
The brake plate on the tomos doesnt reach the stud on the swing arm, but the garelli doesn’t seem to fit properly into the tomos wheel. I think the springs for the brake itself are rubbing but I can’t tell. Anyone ever done the swap or have any tips?
Re: Tomos mags on a Garelli?
It should be able to work. You would need to make a new brake plate tab on the other side of the swing arm. Best way would be to weld something. I have drilled a hole and used a heavy duty bolt. But that is if your swingarm has enough meat to do that.
