Theses connectors are stock on my Vespa’s. They connect to the HTcoil .part store folks are stumped. Anyone know what they are called?
Connector quiz
Re: Connector quiz
Piggyback spade terminal. Amazon
Re: Connector quiz
You don't necessarily need those connectors. You can achieve the same thing using a Y-shaped jumper wire with a male spade on 2 ends (one of which has 2 wires crimped in the connector) and a female on the other end if that makes sense
Re: Connector quiz
yeah I've used a Y connector to serve the same function
Re: Connector quiz
I've found those terminals at my local ACE hardware store in the electrical section.
Re: Connector quiz
Re: Connector quiz
Thanks ! My local Ace pretty small. They don’t even stock 16 gauge primary wire. 8(
Re: Connector quiz
I bought some of those from Amazon. They are a bit flimsy.
Re: Connector quiz
I have done a lot of wiring. more than I ever wanted that is for sure. But the one place I go to for what I need is these guys. The crimping tool is pricey but OMG is it worth it in the long run.
http://www.vintageconnections.com
If you go on ebay you can get the chinese tools for the connectors very useful too. Saved me tons of time and work great.
Re: Connector quiz
That's the biggest goddamn link I've ever seen.
Re: Connector quiz
Yeah.....
Re: Connector quiz
I found them as part of an assortment of oddball spade connectors and adapters at O'Reilly's.
Re: Connector quiz
Damn yall just slice the wire, stick it in your front teeth to strip a half inch of bare wire and twist it together and wrap it in some of those spare treats stickers
Re: Connector quiz
Ha , That's what I did with the bike trailer ground wire a couple years ago .
Day before yesterday , I finally got around to soldering the connection . LOL
Re: Connector quiz
After fixing my Harley turn signals I have to invest in new wire strippers.
Re: Connector quiz
> kenny s Wrote:
> Does anyone know what this is called?
A fuzzy , low light picture . ;)
Re: Connector quiz
Looks like a female bullet connector?
