Connector quiz
Theses connectors are stock on my Vespa’s. They connect to the HTcoil .part store folks are stumped. Anyone know what they are called?
Re: Connector quiz
todd amundson /
Piggyback spade terminal. Amazon
Re: Connector quiz
You don't necessarily need those connectors. You can achieve the same thing using a Y-shaped jumper wire with a male spade on 2 ends (one of which has 2 wires crimped in the connector) and a female on the other end if that makes sense
Re: Connector quiz
yeah I've used a Y connector to serve the same function
Re: Connector quiz
I've found those terminals at my local ACE hardware store in the electrical section.
Re: Connector quiz
Jeremy Homser /
Re: Connector quiz
Thanks ! My local Ace pretty small. They don’t even stock 16 gauge primary wire. 8(
Re: Connector quiz
I bought some of those from Amazon. They are a bit flimsy.
Re: Connector quiz
I have done a lot of wiring. more than I ever wanted that is for sure. But the one place I go to for what I need is these guys. The crimping tool is pricey but OMG is it worth it in the long run.
http://www.vintageconnections.com
If you go on ebay you can get the chinese tools for the connectors very useful too. Saved me tons of time and work great.
https://www.ebay.com/itm/41PCS-Wire-Terminal-Removal-Tool-Car-Electrical-Wiring-Crimp-Connector-Pin-Kit/173277340603?epid=23017953561&_trkparms=ispr%3D1&hash=item28582263bb:g:VrUAAOSw22pfH7Ra&amdata=enc%3AAQAFAAACcBaobrjLl8XobRIiIML1V4Imu%252Fn%252BzU5L90Z278x5ickkSG%252BOFgrj2Yvbvmrj2TAdM7UYQbXxo4jFLUw3YYZxEhxOG36iZGSv8Lm0ODfAnLIeNNK%252FndyyB93nre1pUWlVhrpv%252FqjOgTOoxff%252B323R9n9STf91hiPek9A9HQ%252FZt2xcF8qPyFllXafuEDMqrw1CH8rp3E%252FXaNpZITaoyqsnSX8eiBTvjS47O1v5qZkEI2L7kC8wvs4eeN97ap67yijgX49xH8gcMHcnZIYw20WLYeClQWRDy2jzOgXRh57SQWM6ogj8CNITFLQwgMqcHlSiuHNhQCENRDKbxoGaH46MSsxiahdPRT9CzX0IDAf1TRBrBRj8UXorIWbXYEAfpLjDhGGqX4dZpwQd4mGcm3mJse4iyT%252Bzn8VTfobA9%252FVFvGAmosMPJY%252BrXHJj%252F45X%252BxFBqxf8rpcyqeUJW4mOKQPaquGbrCjkQWliYNF1Ffqh%252FlsWCYpoYUR%252B6luFZmzmhqiGGFHpV59TjSyf4PtTQ7ApsRU5m52BZOommcu9UGqkA%252FqWH5GmnIy9CDvzNIazmVAFti6QF7eUAkMn3r%252F89URiDNYJC2LyR7yPxUXMBJzmmWJbDPNsh3BiF9neV%252BTSSgIQuZ0w2U0D1T6SEMtlWGUq6GOrPmyQ2wgJjcZgu60a4GNqtd3AwrHKh4QK99UdyZALY%252F%252BNXV0JoaZ2l4q%252FTBpw%252FDO3byWm8D022IqSGGeqoVKv1UU7Za3AsrZ%252BEoAcaXMnRY0j99Cw%252BSXJtNd5wiyK0V6WZT4Ao1hcvxscQm16dLQhJ%252FEbOlRAY%252FdEUwXBVXaU2w%253D%253D%7Ccksum%3A17327734060316673038e1564e23b3e9e0a9bdb71d74%7Campid%3APL_CLK%7Cclp%3A2334524
Re: Connector quiz
That's the biggest goddamn link I've ever seen.
Re: Connector quiz
Yeah.....
Re: Connector quiz
I found them as part of an assortment of oddball spade connectors and adapters at O'Reilly's.
Re: Connector quiz
Damn yall just slice the wire, stick it in your front teeth to strip a half inch of bare wire and twist it together and wrap it in some of those spare treats stickers
Re: Connector quiz
Ha , That's what I did with the bike trailer ground wire a couple years ago .
Day before yesterday , I finally got around to soldering the connection . LOL
Re: Connector quiz
After fixing my Harley turn signals I have to invest in new wire strippers.
Re: Connector quiz
Does anyone know what this is called?
Re: Connector quiz
A fuzzy , low light picture . ;)
Re: Connector quiz
Looks like a female bullet connector?
Re: Connector quiz
If you're into the three way action (edited)
