How to clean E50 trans
Working on a E50 and put a magnetic trans fill and so far each time I pull it to check it has lots and lots of gunk on and it just flat ass nasty inside. How do I flash the trans without splitting the case? I’ve changed the ATF two or three times and it’s still nasty so I need a suggestion or two. Thanks all
Re: How to clean E50 trans
Pull clutch and bell, then Spray the crap out of the inside with brake clean....that usually works.
todd amundson /
Straight up gasoline.
Overpriced Parts /
Ya then when done run synthetic motor oil like 0-5w20-30 not junk type F trans fluid for better bearing protection, less clutch fade and longer pad life, less Bushing and gear wear as well as extended/more mi between oil changes if you want to extend change interval
