Hey everyone, looking to get a rear wheel for my fantic pepi but they seem quite rare. It would have to be a rear spoked one since I already bought a front spoked wheel. Does anyone know where to get one? thanks!
Fantic pepi spoked rear wheel alternative?
Re: Fantic pepi spoked rear wheel alternative?
Most Italian 16" rear wheels will work.
I would put an add in the buy/sell section. I'm sure you will find one or one that will work. Most Italian stuff that ran minarelli engines should fit as long as its 16". Alot of the generals that had minarelli were 17". But motron, most fantic, moto bee, yankee peddler, and the list goes on. I'm sure you will find something that will work.
i bought that moped. i got him down to 300$. the top end of the motor was destroyed. it must of gotten a lot of water inside the cylinder since it was so rusted . so bad the polini kit it had was destroyed.
i bought a spare ks only v1 engine so i had options.
any ways i need new drum pads and not sure which ones will work.
Measure the diameter x width and order em..
Harbor freight has a good utility digital caliper for under $20. Or you can order the knock off mitsutoyo from eBay and pretend to be a baller like I do.
I’m a machinist so I got the right tools. I was looking at treatland for parts and they generally list two numbers .
Like 90x20mm
I assume the 20mm is thickness. What got me confused is the 90mm number is that the id of drum on the wheel?
> Like 90x20mm
thanks
> Like 90x20mm
Maybe 20mm is the width ?
so i had time to take apart of my rim
brake p[ad was 19mm thick and i measured the id of the wheel drum surface and got 65 mm. not able to find any drum shoes, any one have a source?
Read this thread . Maybe give you an idea .
https://www.mopedarmy.com/forums/read.php?6,4305830,4305852,flat=1#msg-4305852
