Peugeot 103 LVS-U3 Low compression.
Hi all,
I have a 77 Peugeot 103 and i am having a problem with the compression.
I bought the tecnix stock cylinder kit from treat and installed it and the compression did not improve i am only getting 60 psi same psi i was getting with my old cylinder set up. Currently i have the motor on my work bench that is when i did the compression test after installing the new cylinder, piston and rings
I tested the decompressor valve and it is ok, no leaks i also remove the intake reed valve and inspected it and it is also in good shape.
What should the compression be on a new cyl kit? 60psi seems kinda low?
Any help is appreciated.
Thank you
Re: Peugeot 103 LVS-U3 Low compression.
lap your old head n new cylinder so its flat or maybe your compression tester is no good.
@ggspeed,
The compression tester is good, i got the same results on my old cylinder.
I have read that when you use a compression tester it affects the results due to the extra hose that is atached to the head adding more CC's but don't know for sure if that is correct. I had a head gasket that i received with the kit and i installed it and then found out it was the wrong one it was 2mm in thickness so i used the one i had bought before when i bought a piston and rings for my old cylinder that one is 0.40mm but it did not improve the readings.
I will go ahead and check the head for flatness and see how it is.
Shouldn't the new cylinder be perfectly flat? or what they sell at treat is junk?
> rob res Wrote:
> @ggspeed,
> cylinder.
Gee , you think maybe your old cylinder was still good ?
Test the tester against a known good tester .
And , the little bit of hose making any kind of big difference is bunk .
It's a simple gauge to see approximately how much compression is present .
It doesn't matter if it a few pounds one way or the other .
Why do you think factory manuals state a given amount for optimum/desired compression , plus or minus as much as 10% ?
@ PD,
Yes i maybe it was but it did have some scoring so i was thinking that it was one of the reasons for the low compression.
If i had another compression tester that i could use to compare that would be good but i don't. The compression tested could be defective even though is new i have hardly used it but i have had it for a long time. i will do "O" ring replacement on the adaptors and see if that makes a difference.
As far as the extra hose adding to the cylinder volume that is what i read so i am trying to find out the cause of the low cyl pressure.
The only thing i have not replaced is the decomp valve but i tested it when i removed the head and poured a little bit of water in the cavity where the valve was sitting and it held same when i did the compression test i sprayed some soapy water on top of it and not bubbles so that tells me that it is holding a seal.
Thank you for the input and suggestions
The soapy water is great for the bubble test , but , when testing the chamber seal from inside , remember that water is thicker ( about 30% more dense ) than gasoline and will hold where gas may not . Best to use rubbing or iso propyl alcohol which is much closer . (edited)
@pd,
The way i tested the decompression valve was when i had the head removed from the cylinder and i inverted the head and poured a little water on the seating area of the valve and no water came out on the other end then when i had the head installed i did the soap bubbles test on the exposed area of the valve.
Today i removed the head again and checked to see if it was warped and it was a little so i sanded it to remove the uneven areas until it was straight(flat) then i installed it and did the compression test again and same results 60psi. The cylinder was fine and straight.
I am going to go to my local auto parts store and borrow a compression tester just to verify that mine is good.
I will update then.
Update,
I borrowed a compression tester from my local auto parts store hooked it up and i got 90 psi but it started to loose compression so maybe that compressor tester is also defective or it is somehow loosing compression. I did not have that problem with my compression tested because it would hold the 60 psi so now what? install it or keep troubleshooting i should say that i only replaced the seal on the clutch side not on the ignition side (if it has a seal on that side i don't know) i am going to investigate.
Let me know if you have any comments or suggestions.
Compression testers use the same type core valve as are used in motor vehicle tire stems . If you have a core a core tool , try tightening the core of the tester and see if it holds better .
If its showing 90 then it should be able to start. Pull flywheel, service points, set timing, then squirt some premix in the hole and try to drill start.
