Tomos Sprint A35 Fill Level Bolt Stripped
Benjamin Wheeler /
I picked up a 04 Tomos this summer and just changed the transmission fluid this afternoon. After I drained it I discovered the fill level bolt was stripped...and I couldn't get the bolt out to determine the proper fill level. I replaced the same amount of ATF (type f) that was removed, which was around 7oz or so. Any advice on how much ATF I should be using? Thoughts on trying to replace the fill bolt? Thanks!
Ben
Re: Tomos Sprint A35 Fill Level Bolt Stripped
220 ml. The bolt on mine is stripped as well.
Benjamin Wheeler /
Thank you! I'll just get it filled and roll with it. The fill bolt serves no other purpose, correct?
The one on the side of the transmission cover? That is the only purpose, yes
They hold near 9ozs if you go by the level method
