Re: new exhaust
P D /
> Wolf Wizard Wrote:
> Easiest way to get that top speed better would be to drop the front
> sprocket a tooth One tooth will do more than you thing don’t go too
> crazy or you will loose all your bottom end power
Could it be that you meant adding a tooth to the front ?
Dropping a tooth in front will increase slow speed pickup , but decrease top end speed .
