Motobecane runs backwards ??
Joel Mojica /
So I’ve been trying to tune my vlx50 for the past couple days since it didn’t have any spark ever since the flywheel came lose. Got into the flywheel and clean the points timed it at 1.5 mm Btdc Started it and now it’s running backwards. I used a buzzeti timing tool to find the exact position. From my understanding when your too advanced or retarded ? Not sure what’s going on here. Should I try to time after tdc ? Also I have a 74cc airsal kit 15.15 del carb Doppler exhaust
Malossi variator.
