Re: Motobecane runs backwards ??
EH FCC of the QCB /
Tyler is right. The cam must have moved when you put it on.
Did you find the highest point the pin would move on the timing tool? Then lock it in with the set screw and then move it down 1.5mm?
Do you have a light to check it?
The Wikki does a good job explains it.
https://www.mopedarmy.com/wiki/Guide_to_Motobecane_spark_and_timing
