Re: QCB Yamaha Sting Build Off: Gator vs. Potato
On these motors there is no gasket for the case halves. Yamabond is required.
> Gator San Juan Wrote:
> I need to cite my source for the term "It's just mopeds" - Charlie
> Buzzard. Please call off your legal goons Charlie.
Wait... My goons are legal?!
SWEET!
Team Gator: Decided to go with an HPI setup. The wiring on this thing was wack. There were connectors spliced in for no reason.
and a janky PW50 stator. The stator screws were stripped out so the impact had to come out.
Removed the oil pump too. I am not convinced that the pump will provide enough oil for a Malossi kit setup.
Ooof - beautiful piston mixed with a little water..
Must have been liquid cooled.
Cleaned up the motor, added block off plate, working on intake and cylinder next.
(edited)
So... for my top end I decided to go a different route a hobbit DR kit. I’ve seen this kit on a QT50 some where on the inter-webs. Since the QT50 and the Sting are very similar in motor parts I figured why not give it a try. I had to drill out the holes for the studs because the sting has closer studs. I also had to space the kit out from the case 3mm for the ports to line up at BDC. I also ported like a derbi Metrakit.
This means I can run a hobbit pipe now.
I went with a MLM G-104. I can’t wait to hit vtec on my Yamahonda.
Why not the derbi 47mm Airsal kits??
That was my plan with my qt50 but piston selection is annoying because 10 pin vs 12 pin.
Man Charlie - not everything needs to get a Derbi Airsal kit! :-)
Found out last night that Yamaha Stings make chocolate pudding in the rear gearbox! Cleaned that up and regreased it.
Did some horrible case matching, and did a little painting.
Hahah looking good Matt!
Plastics are cleaning up nice and added a little chomp.
Loving this thread so much. Thanks guys!
Thanks Jay! We are having a good time with it too. Here's what I have been up to. First, added a VM20 MLM intake and cut off the VM mount for a spigot mount. I don't understand why the mating surface is powder coated but whatever.
The intake was wobbly, so I decked it and got the powder coat off. It's nice and even / smooth now.
I added a red "race" 21 phbg and a super street head for the Malossi kit. The Malossi kit is known to have clearance issues with the spark plug because of dome-shaped piston.
Going to add an HPI set up soon and other little goodies. :-)
If you go with the HPI, I'd recommend adding the weight that you can get for them.
Otherwise I think the mini rotor will be hard on the transmission.
Yeah on that rear end, I was just looking at that on the pdub.. woof that grease! I was thinking about using corn head grease, it turns liquid when it's hot like gear oil then solids up when it's cold like grease. They use it in snowblower gearboxes and farm equipment.
If you do that - report back. I'd like to hear the results!
Motor is back on! Mounted the Gianelli Derbi flat reed pipe really easily (without hacking) so Derbi purists can calm down. Needed to cut the case mount down for the stock pipe but not bad! Rear bracket on the Gianelli lines up perfectly. Polished the crap out of it too.
Wow, that pipe looks right at home on there. I dig it
Jack Rutherford /
> Metrakit.
nice. I'm doing this! I may go with another hobbit kit though.
Can't decide if I do left or right....
Drop the seat you'll be using on an then have a look .
If you’re using low bars go left, high boi’s go right
Right
Original fairing
That is exactly what I told him earlier.
