Re: Trike build
Satan 666 /
> Trent Anderson Wrote:
> I'm very interested in how this works out. I have pretty much the same
> setup; Pryer rear end from a Batavus going on to a Motron. I'll need to
> make the swing arm connection wider and get a chain tensioner as well.
> It does look like stock shocks will line up. Not sure how a stock V1
> pipe will connect. Good to know you can swap the rear sprocket, though.
> What are you referring to regarding a #35 or #41 chain? Do they not
> take #415
The swingarm on the motron is wider than the mount on the trike. I am just gonna cut the tube on the motron frame and use washers or spacers to line up the chain. Should be pretty easy. Pipe mounting will be pretty simple also. Just gonna have to cut the header so the pipe will fit under the trike frame. All the pipes I have are more up swept so they will not work. This is as far I got last night.
  Trike buildTopic by: Satan 666 Satan 666 12/25/20 05:44PM
  Re: Trike buildRe: Satan 666 Satan 666 12/25/20 05:48PM
  Re: Trike buildRe: Satan 666 Satan 666 12/25/20 05:56PM
  Re: Trike buildRe: Saabsonettguy . Saabsonettguy . 12/25/20 07:05PM
  Re: Trike buildRe: Graham Motzing Graham Motzing 12/26/20 07:22PM
  Re: Trike buildRe: Satan 666 Satan 666 12/26/20 07:47PM
  Re: Trike buildRe: Malcolm B Malcolm B 12/27/20 07:14AM
  Re: Trike buildRe: Graham Motzing Graham Motzing 12/27/20 08:55PM
  Re: Trike buildRe: Satan 666 Satan 666 12/27/20 07:37AM
  Re: Trike buildRe: Malcolm B Malcolm B 12/27/20 07:55AM
  Re: Trike buildRe: Rebel Moby Rebel Moby 12/27/20 12:17PM
  Re: Trike buildRe: Rebel Moby Rebel Moby 12/27/20 12:20PM
  Re: Trike buildRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 12/28/20 02:25PM
  Re: Trike buildRe: Graham Motzing Graham Motzing 12/28/20 02:32PM
  Re: Trike buildRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 12/28/20 02:26PM
  Re: Trike buildRe: Satan 666 Satan 666 12/28/20 03:12PM
  Re: Trike buildRe: Satan 666 Satan 666 12/28/20 03:13PM
  Re: Trike buildRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 12/28/20 08:03PM
  Re: Trike buildRe: Trent Anderson Trent Anderson 12/28/20 09:48PM
  Re: Trike buildRe: Satan 666 Satan 666 12/29/20 10:23AM
  Re: Trike buildRe: Satan 666 Satan 666 12/30/20 12:59PM
  Re: Trike buildRe: Saabsonettguy . Saabsonettguy . 12/30/20 01:07PM
  Re: Trike buildRe: Satan 666 Satan 666 12/30/20 01:42PM
  Re: Trike buildRe: Satan 666 Satan 666 12/30/20 01:45PM
  Re: Trike buildRe: Saabsonettguy . Saabsonettguy . 12/30/20 04:20PM
  Re: Trike buildRe: Satan 666 Satan 666 12/30/20 04:21PM
  Re: Trike buildRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 12/31/20 02:36PM
  Re: Trike buildRe: Satan 666 Satan 666 12/31/20 03:13PM
  Re: Trike buildRe: Satan 666 Satan 666 01/06/21 06:20PM
  Re: Trike buildRe: Satan 666 Satan 666 01/10/21 01:52AM
  Re: Trike buildRe: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/10/21 09:29AM
  Re: Trike buildRe: Satan 666 Satan 666 01/10/21 10:49AM
  Re: Trike buildRe: Satan 666 Satan 666 01/16/21 08:27PM
  Re: Trike buildRe: Satan 666 Satan 666 01/16/21 08:36PM
  Re: Trike buildRe: Trent Anderson Trent Anderson 01/18/21 02:52AM
  Re: Trike buildRe: Satan 666 Satan 666 01/18/21 04:18PM
  Re: Trike buildRe: Satan 666 Satan 666 02/16/21 09:41PM
  Re: Trike buildRe: Stephen Keller Stephen Keller 02/23/21 11:25AM
  Re: Trike buildRe: Satan 666 Satan 666 02/16/21 09:43PM
  Re: Trike buildRe: Satan 666 Satan 666 02/21/21 08:20PM
  Re: Trike buildRe: todd amundson todd amundson 02/22/21 12:12PM
  Re: Trike buildRe: Brandon Love Brandon Love 02/23/21 06:55AM
