Re: Exhaust Peugeot 103 SP
Graham Motzing /
Yeah you should be fully variated at top speed, you need to gear way down and get the right belt.
European market 103 are different from the ones we have in the u.s., yours should be 3 port and much better. If you have an Sha carb, non-restricted reeds and fix the gearing you should easily be going 35+ with good acceleration. Don't buy a pipe until you have all that sorted out.
