Piaggio si oil rear mozzo air exit
Valentin Mishu /
Hello i guys , i have mounted my rear pinasco mozzo with 11 to 1 ratio shatfs inside i have put around 65ml transmision oil inside . Polini high speed front vario engine polini d46....and when i push more then 55 kmh it spits litle oil on the air exit port of the mozzo...the one responsabile for high pressure i think that takes air out..now oil goes out there also...
i think only the extra oil ?
its not normal ? or its ok until it remains the corect amount of oil inside?
Thank you , Valentin
Re: Piaggio si oil rear mozzo air exit
isnt there a fill hole, just dill till it drains ou.
What transmission fluid are you using? Thinking it should be gear oil pretty thick stuff.
Valentin Mishu /
i have used 75w90 castrol .
Thanks, Valentin
if a small bit is leaking out of air bleed hole its fine, if they are new gears you might wanna change the gear oil a few times as the gears mesh together theres going to be metal in there.
Valentin Mishu /
Thank you . Good to know .
