> roots to wings Wrote:
> So detective you are in the never seal club? I got one of the Speedo’s
> from treats. Not sure I understand your nomenclature but I had to file
> down the needle that goes in the speedo and hun to get mine to work.
> What did you find worked best on the rust on your rims?
In my case the Treats unit doesn’t fit in any way. The tabs are too wide and the axle hole too big. For the rust I loosened it with a wire wheel and then hit it with simple green. Not perfect, but certainly good enough. You can’t see it anyway.
MKL
