> Moshe Levy Wrote:
> > Overpriced Parts Wrote:
> > Your bike is actually a Newport II, not a Newport, ignition coil
> > location and sprockets are different (stock 2 hp e50 has 16x45 gearing
> > and za50 has 18x40 gearing, e50 has the ignition coil on the engine)
> > 18x40 Za50 sprockets will probably be too high gearing for your e50 to
> > pull it, maybe 17x40 if you have a good tuned clutch but 16x40 will be
> > fine,
> > What happened to the original za50 engine? See if the person who you
> > bought the bike off of still has it, It’s a better engine for takeoff
> > and hills
> Interesting. Yes this one had 18/40 and an e50. There’s also a “1.5 HP”
> sticker on it which looks original. My Tomos is a two speed so I really
> do want a single speed on this Puch. I’ll deal with the proper gearing
> on the rebuild when we get there.
> MKL
Your engine is not original it has been changed to a e50 I guarantee it, theres no way a Stock E50 could’ve pulled 18x40 gearing let alone a 1.5 hp e50 maxi that comes with 15x45 gearing that’s even lower than 2HP 16×45 Gears
A stock 1.5 Hp za50 Newport II still comes with 18x40 gears,
I had or worked on several red Newport II’s over the years and I got one right now, They come with the good second generation za50 engine that engine Vin number matches the frame, never come from the factory With a e50,
For the coil to be on the frame it’s a specially made Za50 frame that has the coil mounts Welding in at the factory because there is no coil mounting slot on a za50 like a e50 engine has.
Look at the one I have now that I’m going to be restoring sometime it’s a za50 that the Vin matches the frame.
Some Newport II’s especially the black ones have normal 17 digit Vin numbers like a car and engine number doesn’t match but most red ones don’t but still come with za50 engines
A 1980 second generation puch Za50 2 speed is far superior to a 2speed tomos engine and after you flip the second gear clutch it shifts like a Chevy powerglide transmission with full and partial throttle kick down making it a blast to ride by keeping you in the power at all times
