Re: How bad are Tomos brakes and forks?
Jay Rivett /
Moped drum brakes suck. You cant compare it to a cantilever or style brake because it is stopping in different ways. Also your walmart bike weighs like 20lbs. You moped weighs over 100lbs.
The brakes may have started to glaze over after years of use. Causing a slick surface. You can sand your brake pads to roughen them up. You can also file in some grooves which creates more stopping points along your brake pads which can help. Also clean up the drum area real good with some brake cleaner. They make aftermarket pads you can grab if what you have just wont work.
If you want really good stopping power. Purchase a replacement set of forks that have a disc brake setup.
  How bad are Tomos brakes and forks?Topic by: Rosario Miller Rosario Miller 01/10/21 09:42AM
  Re: How bad are Tomos brakes and forks?Re: Saabsonettguy . Saabsonettguy . 01/10/21 09:49AM
  Re: How bad are Tomos brakes and forks?Re: Nick MBC Nick MBC 01/10/21 09:56AM
  Re: How bad are Tomos brakes and forks?Re: Rosario Miller Rosario Miller 01/10/21 09:58AM
  Re: How bad are Tomos brakes and forks?Re: Jay Rivett Jay Rivett 01/10/21 12:08PM
  Re: How bad are Tomos brakes and forks?Re: P D P D 01/10/21 12:20PM
  Re: How bad are Tomos brakes and forks?Re: Aaron Blair Aaron Blair 01/10/21 01:16PM
  Re: How bad are Tomos brakes and forks?Re: Lou MAGNETO Lou MAGNETO 01/10/21 02:10PM
  Re: How bad are Tomos brakes and forks?Re: Hepatitis J [OFMC] Hepatitis J [OFMC] 01/10/21 01:21PM
  Re: How bad are Tomos brakes and forks?Re: Overpriced Parts Overpriced Parts 01/10/21 02:13PM
  Re: How bad are Tomos brakes and forks?Re: Jackerz ! Jackerz ! 01/10/21 02:41PM
  Re: How bad are Tomos brakes and forks?Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/10/21 03:30PM
  Re: How bad are Tomos brakes and forks?Re: pat splat pat splat 01/10/21 05:18PM
  Re: How bad are Tomos brakes and forks?Re: Rich Condor Rich Condor 01/10/21 09:33PM
  Re: How bad are Tomos brakes and forks?Re: JBOT Admin JBOT Admin 01/10/21 09:57PM
  Re: How bad are Tomos brakes and forks?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/11/21 10:15AM
  Re: How bad are Tomos brakes and forks?Re: Rosario Miller Rosario Miller 01/10/21 10:01PM
  Re: How bad are Tomos brakes and forks?Re: P D P D 01/11/21 08:44AM
  Re: How bad are Tomos brakes and forks?Re: Ryan Graeme Ryan Graeme 01/11/21 06:27PM
  Re: How bad are Tomos brakes and forkRe: Rosario Miller Rosario Miller 01/11/21 12:00PM
