Re: How bad are Tomos brakes and forks?
Tri-ped Dave O.D.B. /
Yes, try this:
Remove the brake shoes. If they have 1/8" or more left of material, do not replace them. Sand all of the glaze off them, then spray off all of the grit from sanding with brake cleaner and let dry. While that is drying, also sand with 200 grit or emory the drum where the shoes contact. remove any corrosion or rust. Also spray clean with brake cleaner and let dry. Re-assemble and marvel at how much better the de-glazed brakes work!
  How bad are Tomos brakes and forks?Topic by: Rosario Miller Rosario Miller 01/10/21 09:42AM
  Re: How bad are Tomos brakes and forks?Re: Saabsonettguy . Saabsonettguy . 01/10/21 09:49AM
  Re: How bad are Tomos brakes and forks?Re: Nick MBC Nick MBC 01/10/21 09:56AM
  Re: How bad are Tomos brakes and forks?Re: Rosario Miller Rosario Miller 01/10/21 09:58AM
  Re: How bad are Tomos brakes and forks?Re: Jay Rivett Jay Rivett 01/10/21 12:08PM
  Re: How bad are Tomos brakes and forks?Re: P D P D 01/10/21 12:20PM
  Re: How bad are Tomos brakes and forks?Re: Aaron Blair Aaron Blair 01/10/21 01:16PM
  Re: How bad are Tomos brakes and forks?Re: Lou MAGNETO Lou MAGNETO 01/10/21 02:10PM
  Re: How bad are Tomos brakes and forks?Re: Hepatitis J [OFMC] Hepatitis J [OFMC] 01/10/21 01:21PM
  Re: How bad are Tomos brakes and forks?Re: Overpriced Parts Overpriced Parts 01/10/21 02:13PM
  Re: How bad are Tomos brakes and forks?Re: Jackerz ! Jackerz ! 01/10/21 02:41PM
  Re: How bad are Tomos brakes and forks?Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/10/21 03:30PM
  Re: How bad are Tomos brakes and forks?Re: pat splat pat splat 01/10/21 05:18PM
  Re: How bad are Tomos brakes and forks?Re: Rich Condor Rich Condor 01/10/21 09:33PM
  Re: How bad are Tomos brakes and forks?Re: JBOT Admin JBOT Admin 01/10/21 09:57PM
  Re: How bad are Tomos brakes and forks?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/11/21 10:15AM
  Re: How bad are Tomos brakes and forks?Re: Rosario Miller Rosario Miller 01/10/21 10:01PM
  Re: How bad are Tomos brakes and forks?Re: P D P D 01/11/21 08:44AM
  Re: How bad are Tomos brakes and forks?Re: Ryan Graeme Ryan Graeme 01/11/21 06:27PM
  Re: How bad are Tomos brakes and forkRe: Rosario Miller Rosario Miller 01/11/21 12:00PM
