Re: How bad are Tomos brakes and forks?
JBOT Admin /
Ok look.
I’ve made ever moped, every moped I’ve ever used to have great brakes.
Few things to do.
1. Sipe the pads (dremel slots in each shoe perpendicular to the shoe or on an angle) scuff up shoe top after with sandpaper
2. Lube connection points and the paddle that moves the shoes. Make sure it moves easily
3. Scuff the drum with sandpaper then clean well.
4. If the hand levers aren’t returning well, add springs on the cables between the stops
5. If the cable is too thin it will stretch and not grab well. Use at least 1.5-2mm inner cables.
6. Adjust cables and sometimes you must cut a lead end off and add a Knarp to get things closer
7. Engage the brake when tightening the axle to center the whole shebang
This is all I do and my brakes are kick ass. Even on my tiny 16in 5 stars. Sipes are the most amazing thing. I do them to all brakes and clutches (edited)
  How bad are Tomos brakes and forks?Topic by: Rosario Miller Rosario Miller 01/10/21 09:42AM
  Re: How bad are Tomos brakes and forks?Re: Saabsonettguy . Saabsonettguy . 01/10/21 09:49AM
  Re: How bad are Tomos brakes and forks?Re: Nick MBC Nick MBC 01/10/21 09:56AM
  Re: How bad are Tomos brakes and forks?Re: Rosario Miller Rosario Miller 01/10/21 09:58AM
  Re: How bad are Tomos brakes and forks?Re: Jay Rivett Jay Rivett 01/10/21 12:08PM
  Re: How bad are Tomos brakes and forks?Re: P D P D 01/10/21 12:20PM
  Re: How bad are Tomos brakes and forks?Re: Aaron Blair Aaron Blair 01/10/21 01:16PM
  Re: How bad are Tomos brakes and forks?Re: Lou MAGNETO Lou MAGNETO 01/10/21 02:10PM
  Re: How bad are Tomos brakes and forks?Re: Hepatitis J [OFMC] Hepatitis J [OFMC] 01/10/21 01:21PM
  Re: How bad are Tomos brakes and forks?Re: Overpriced Parts Overpriced Parts 01/10/21 02:13PM
  Re: How bad are Tomos brakes and forks?Re: Jackerz ! Jackerz ! 01/10/21 02:41PM
  Re: How bad are Tomos brakes and forks?Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/10/21 03:30PM
  Re: How bad are Tomos brakes and forks?Re: pat splat pat splat 01/10/21 05:18PM
  Re: How bad are Tomos brakes and forks?Re: Rich Condor Rich Condor 01/10/21 09:33PM
  Re: How bad are Tomos brakes and forks?Re: JBOT Admin JBOT Admin 01/10/21 09:57PM
  Re: How bad are Tomos brakes and forks?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/11/21 10:15AM
  Re: How bad are Tomos brakes and forks?Re: Rosario Miller Rosario Miller 01/10/21 10:01PM
  Re: How bad are Tomos brakes and forks?Re: P D P D 01/11/21 08:44AM
  Re: How bad are Tomos brakes and forks?Re: Ryan Graeme Ryan Graeme 01/11/21 06:27PM
  Re: How bad are Tomos brakes and forkRe: Rosario Miller Rosario Miller 01/11/21 12:00PM
