Re: How bad are Tomos brakes and forks?
> JBOT Admin Wrote:
> 7. Engage the brake when tightening the axle to center the whole shebang
^this makes a huge difference, and works on the same principal that self adjusting drum brakes on cars do. The center holes on brake plates are usually a loose fit, and therefore the pads are never truly concentric with the brake drum if you just slap them on. By engaging the brakes while you tighten down the axle nuts (or the nut that secures the brake plate on some models), you ensure that the pads are set in a position where they have as much contact as possible with the drum. The smallest amount of play between the center hole on the brake plate and the axle is all it takes to severely weaken braking power.
Its worth noting that new brake shoes aren't always the perfect shape to mach the radius of the brake drum, so they may need to wear in for a bit before you really notice a difference. If it takes a while, you might want to check the brake shoes again and lightly sand down the high spots, and reassemble the same way.
Also, wear a respirator when grinding/sanding brake shoes, and don't sipe/grind old brake shoes that may have asbestos
  How bad are Tomos brakes and forks?Topic by: Rosario Miller Rosario Miller 01/10/21 09:42AM
  Re: How bad are Tomos brakes and forks?Re: Saabsonettguy . Saabsonettguy . 01/10/21 09:49AM
  Re: How bad are Tomos brakes and forks?Re: Nick MBC Nick MBC 01/10/21 09:56AM
  Re: How bad are Tomos brakes and forks?Re: Rosario Miller Rosario Miller 01/10/21 09:58AM
  Re: How bad are Tomos brakes and forks?Re: Jay Rivett Jay Rivett 01/10/21 12:08PM
  Re: How bad are Tomos brakes and forks?Re: P D P D 01/10/21 12:20PM
  Re: How bad are Tomos brakes and forks?Re: Aaron Blair Aaron Blair 01/10/21 01:16PM
  Re: How bad are Tomos brakes and forks?Re: Lou MAGNETO Lou MAGNETO 01/10/21 02:10PM
  Re: How bad are Tomos brakes and forks?Re: Hepatitis J [OFMC] Hepatitis J [OFMC] 01/10/21 01:21PM
  Re: How bad are Tomos brakes and forks?Re: Overpriced Parts Overpriced Parts 01/10/21 02:13PM
  Re: How bad are Tomos brakes and forks?Re: Jackerz ! Jackerz ! 01/10/21 02:41PM
  Re: How bad are Tomos brakes and forks?Re: Tri-ped Dave O.D.B. Tri-ped Dave O.D.B. 01/10/21 03:30PM
  Re: How bad are Tomos brakes and forks?Re: pat splat pat splat 01/10/21 05:18PM
  Re: How bad are Tomos brakes and forks?Re: Rich Condor Rich Condor 01/10/21 09:33PM
  Re: How bad are Tomos brakes and forks?Re: JBOT Admin JBOT Admin 01/10/21 09:57PM
  Re: How bad are Tomos brakes and forks?Re: Brandon Weiss (Detective brandon to you) Brandon Weiss (Detective brandon to you) 01/11/21 10:15AM
  Re: How bad are Tomos brakes and forks?Re: Rosario Miller Rosario Miller 01/10/21 10:01PM
  Re: How bad are Tomos brakes and forks?Re: P D P D 01/11/21 08:44AM
  Re: How bad are Tomos brakes and forks?Re: Ryan Graeme Ryan Graeme 01/11/21 06:27PM
  Re: How bad are Tomos brakes and forkRe: Rosario Miller Rosario Miller 01/11/21 12:00PM
