Re: Condenser Mount
Fern Fields /
The new one has no wires. The wires are a part of the stator/wiring system that connect to the condenser. The blue wire runs to the engine shutoff switch and secondary ignition coil. The red wire connects to the points. The copper wire on top (not pictured) comes from the ignition coil.
Here's a wiring diagram for reference.
https://vintagemopeds.files.wordpress.com/2014/03/1978-sachs-westlake-wiring-diagram.pdf
