A polini kit was developed to use a stock maxi (high torque) head
All you Gotta do is use one of those, though I sand or mill down the two compression rings on the Hi torque maxi head so it’s flat for a bit more compression if you use the stock gasket that comes with the kit though it’s very feeble you’ll get close to the squish you need
