Hey folks. Just me dorkin around in the ol Ped Pad.
I recently acquired this tomos as I have been wanting to play around with one again. And I wanted a good 2 speed bike for my lady. The bike has all the plastics which is pretty cool but after some replacement parts I might not be able to keep all of them on or I will at least need to modify them slightly.
The previous owner had replaced a few things already so It has a 15sha and new estoril with the adjustment screw. Bonus!
I grabbed a crank pipes intake to replace that stock "Z" intake which had the oil injection inlet on it. I also got a throttle assembly with the switches from Terry Gerker, thanks again man! The bike has some thumb throttle like for a quad so I wanted to replace that. Silly me forgot to order a new throttle cable. So I at least added the new perch and brake lever so I had the controls and repositioned the thumb throttle to work better with the setup.
The intake needed a new intake which I also didnt order so I made one out of some thick gasket paper. Sealed things up nicely. Before that i took the reeds apart and inspected that everything looked ok, flipped them anyway just to make sure it sealed if there was any slight warping. Got it all buttoned back up. The carb had that 58 jet in it. Which made the bike run, and was not lean, but i put in a 63, and put in a different screen to allow more airflow. I havent done any plug chops yet but I dont think I'm running lean.
I did try out that 3d printed sha slide in this bike but like many other reed setups it had a runaway bike affect that could not be stopped without killing the ignition. So I put the stock slide back in for now. I have some slides to play with some profiles but right now I'm happy with how it feels. I was running out of daylight and gas today so tomorrow I'll do some GPS'd runs, but according to the stock speedo I was hitting 40, and getting there pretty darn quick with my 225lb butt on it.
