Treatlands Puch maxi 12 volt cross over
Dougllld Williams /
I'm having trouble with treats 12volt system switch bike fired up for awhile but when throttled with a load on it it dies has not fired up since I know it's in the ignition do I need to add a regulator to the system being it Sparks with a 6 volt the lights being 12 any help would be much thanked just did a complete motor rebuild with a polini kit and can tell when she is done I'll have a nice powerful ride it's killing me I can't ride her
Re: Treatlands Puch maxi 12 volt cross over
Post a link or photo of what stator you have. If your ignition source coil has one wire, the ignition circuit will operate independent from the lighting circuit.
todd amundson /
The treats 12 volt coil has nothing to do with your points system if that’s what you’re running.
Points gap to small?
Coils rubbing on the flywheel?
Blue/black wire grounded?
Bad condenser?
