Re: fork boots -- necessary?
Erwin Schrodinger /
Yeah, for sure. I picked up these old style covers. https://www.treatland.tv/OEM-tomos-bullet-fork-rubber-protective-shield-p/oem-tomos-fork-rubber-219226.htm
> Papa _ Wrote:
> Fork boots keep grit out of the fork seals on real forks.
> Any teeny tiny amount of abrasive material would be like sanding the
> surface. Forks are supposed to be tight. Removing material will make
> them loose and wobbly.
> Boots are important in environments where dust and grit is blowing
> around or likely to contaminate the fork seals. On real hydraulic forks.
> If you keep them clean, like average clean, I think you’re safe to not
> worry too much on a moped. Unless you are riding offroad in the desert.
