> Papa _ Wrote:
> when you guys are talking about bent, you mean metal is deformed bent or
> the plastic bushings are so worn that they look bent?
No actual bends in the metal forks. Usually around the triple tree area. Their stuff is weak. It just pushes in. You can bend them yourself if you push in on them hard enough. You cant to that with EBRs or even some other stock forks.
