Za50 center case gasket, svg files?
Jesse Nordlander /
Engine binds with stuffy crank, old gasket was slightly thicker than treats replacement. In process of trying this on a cricut machine. Does anyone have an accurate measurement file? Using a cereal box at .019 to replace .010 treats gasket.
Re: Za50 center case gasket, svg files?
Jesse Nordlander /
Off by only .100, adjusting and moving to ceral box. Wife doing all the hard work
Tweaker trash /
Yea we need to start scanning more gaskets , now that people have vinyl cutters
Jesse Nordlander /
Thanks for that. Hard to believe how far things have come, last gasket i used a ball peen and exacto.
Overpriced Parts /
gasket has a little bit to do with it but you didn’t shim correctly either
Jesse Nordlander /
guilty, I assumed crank in box of parts was the original. cheek to cheek was same for both oem and stuffy installed. I will be uploading every gasket I copy to wiki
