E50 Clutch Cover Woes
Moshe Levy /
Hi All - Need some advice. I’m in the middle of a 1980 Maxi rebuild. When I install the clutch cover on the engine case, the cam which would be pulled by the clutch cable is stuck tight. I mean solid! I’ve put it together per pictures I’ve found online, but I don’t have other Puchs here for reference. I think the cam should move a little, but it doesn’t. Any advice appreciated.
MKL
