Mlm hobbit subframe covers.
I'm in the prosses of planing a hobbit build. I'm thinking of running a mlm subframe but plan on riding it pretty much daily. My problem is I don't like the idea of the drive belt and variator pulley being splashed with salt mud and sand. Thinking of comming up with a cover for it. If any one has any ideas or even posibly interested in one if I made more than one I thank you for your input. As I come up with designs I will keep you all posted. (edited)
Re: Mlm hobbit subframe covers.
If you’re riding off-road that’s a good idea.
If you’re on streets mostly don’t bother.
There are quite a few gravel and dirt roads around my area. And I do tend to take short cuts along creek banks and trails when going across town.
Sometimes an open trans is better.
If you get water inside a cover it stays wet for longer and rusts more. But good luck with the project.
Open trans is not sick if you get your belt wet. It slips like crazy then power wheelies you into a tree.
