> LSLB RXb Wrote:
> Leave the airbox, they do a lot for longevity vs the measly
> "performance" increase you get from running with out one. (not to
> mention having to rejet with every 8-10ºc temp change you encounter)
> oil injection is fine too. there is a customer at my shop who rides
> between 200 to 400 miles per week with an a35 tomos with the stock
> cylinder, a hunter pipe and the stock sideshot intake and stock airbox
> with the oil injection still working. He's put probably 2,500 miles on
> the bike since he bought it in November 2020. He even rode it from
> Boston to Hartford and back last weekend, something like a 200 mile
> round trip.
> my point is there is no need to deviate from what Tomos put on there.
> The stock airbox is great. its all great.
> you might just need to turn up your idle screw a 1/2 turn?
Yeah I was hesitant about modding stuff cause I know it runs fine in stock form and I'm not looking for extra performance. I'm much like the customer you mention, though my commute is shorter. I also don't have oil injection (didn't come with it), though if nothing else I'd have been forced to get rid of it with the mods I have planned so maybe it's a good thing cause it means I can keep it mechanically stock. It's not idle, I actually raised it a few whole turns in an attempt to compensate but it didn't really help.
> ♣Slew Foot♣ Wrote:
> No if it was injected they block the hole in the intake with a screw or
> bolt it maybe loose or missing. The airbox ditch and use a highflow
> filter or metal disk.
> But seriously the gas cap vent check it cause the main symptom is
> holding in 1rst gear and not shifting due to low rpms cause of lack of
> fuel.
> It could be a passage in the banjo to floatbowl float pin or the
> vertical tube or even the holes in that tube. It could be the internal
> petcock filters length of fueline inline filters and diameter of
> fuelline. It sounds as tho it is fuel staves on take off restriction in
> fuel flow go from there be warned carb problems are often electrical
> gremlins and vice versa.
I did check, I promise it's not the gas cap vent :p I have some suspicion of the fuel itself rather than the amount thereof but I can't fully rule that out just yet. I'll let you all know. Some gas stations here offer ready-made 50:1 premix. The benefits are that you don't have to mix yourself but more importantly to me a lack of ethanol. The biggest downside is that it doesn't quite get as much use as the others (most moped tanks are only around 1 or maybe 2 gallons after all) so the fuel in there can be pretty old in some cases. Thankfully they made sure the oil doesn't settle and mess up your mixture. (edited)
