Honda express compression
Alright guys I know a lot of people have talked about this, but I’m hoping you guys can clear it up. I started my motor ran it till it was hot. The air filter was off, my throttle was wide open. I turned it over 10 times and It only read 35psi. Can it even run with compression that low?? It dies randomly but I can still hit 30mph. Its sometimes hard to start.
Re: Honda express compression
Sounds like you need a new guage .
Will Harrington /
Bran new
No matter . New does not mean functional .
See about using one from an auto parts store . Most decent stores have loan a tool programs .
I doubt any bike would run at 35#s compression .
Jesse Nordlander /
Put your finger over plug hole and spin it. If you can hold it there without compression shooting past, it's low. If theres a very audible sound of air blowing your finger from seated over hole, it's 100+ psi
The fact that it runs indicates your gauge is trash anyway
Sounds like you have a crank seal leaking. The snap-on compression guage I used on mine after installing new piston and rings read lower than I expected. Was like 60-65 psi and ran/started flawlessly. Put 2000+ miles on that motor before selling it a year ago.
Here we go... They are low compression motors.
(edited)
My Simplex is supposed to be able to run on 60 pounds compression , but , it runs a lot better with about 110 pounds compression .
It should be noted that with the higher compression , a better connecting rod should be used , as the OEM rod is a limiting factor .
I would think the same would apply to any motor designed similarly .
Thats nice, if you wanna go all out with modifications. I am referring to stock or o.e.m. parts. Apples to oranges really. How many expresses have you owned again???
And I wouldn't recommend raising compression unless you are prepared to deal with the extra heat created. Stock runs hot enough...
(edited)
> live ɘvil Wrote:
> but
Agreed . Mods to OEM = apples to oranges .
No matter how many of what I've owned . The same applies .
I simply exemplified what you said^ . ;)
