Puch Magnum MKII Problem Starting?
Hi, I've been having an issue with my Push Magnum MKII. I can't get it started lately without pulling out the spark plug and heating it up and then popping it back in the bike. When I do this without fail it starts. Does anyone have an idea what might be the problem? I've been trying to figure out if I just keep flooding the tank immediately after failing to start the bike the first time or what? Any help would be appreciated.
Re: Puch Magnum MKII Problem Starting?
Is it bone stock?
If it is then maybe try a new plug.
Cleaning the carb is always a good idea.
Anything beyond that and you'd need to tell us a little more
New plug, maybe needs choke to start, agree need more details on the build
Yeah the plug is fouled if you are doing that to it. Get a new plug, use the choke.
i had a problem like this in the past with mine,are you using a bing? i think they tend to flood your cylinder and or you may have a leak so double check your head nuts
