Just another maxi
Jesse Nordlander /
Picked this sweet bright blue maxi inadvertently for $100 the other day. Was only picking up an air compressor.
The guy said he thought tank was crispy. Offered it free, I gave him minimum value of parts.
Turns out tank is beyond crispy. Required strap wrench to get cap off, 5 minutes into muriatic treatment it pops a leak.
Re: Just another maxi
That box is sweet
♣Slew Foot♣ /
Milkbox is awesome...
Jesse Nordlander /
Def adds some funk, luckily I had a clean tank maxi, missing nearly everything. Swapped everything over, fired right up and chugged out. Plume of smoke indicates trans crank seal has seen better days. (edited)
This is why you should have a shop full of the things.
Jesse Nordlander /
Darn right, maximalism!
Is that a reflector on the box or a giant led light? (have seen them that big)
Jesse Nordlander /
That's just a reflector
Need to see if an axe handle will slip into the box straps. Nobody starts shit with a guy brandishing an axe
