Is this a good magnum setup? help me tweak!
Jon /
Hows this setup sound?
New 50 cc kit with bigger ports
high comp head
19 mm dellorto PHBG carb (should i get spigot style or clamp on?)
Malossi air filter
What exhaust will fit a magnum without modification? Or is the modification worth it/how hard is it?
And this is all bolted up to a ZA50 2 speed bottom end.
Anything else you can suggest, other than a bigger kit :p ?
