Re: Is this a good magnum setup? help me tweak!
B Brick /
If you really want to use this kit. Then I suggest you get the cylinder first. Then measure the intake port window, where it exits on the piston side, not where the manifold bolts on. Calculate its area. And just see what carb would be 85% of that area. Round up to an easily gotten carb size. Then buy your carb and intake.
