Re: Who has the fastest Puch !
Jeffrey Strichart /
My friends and I all made very fast mopeds back in the late 70s/early 80s. What we did was drill out the ports as big as we could, bore out the intake manifold and carburetor as big as we could (although I put a YZ80 carb on my Negrini), put in the biggest jet we could get, cut the piston so it would clear the new larger port, remove the air filter, remove the exhaust pipe entirely (more on that later) and of course we changed the gearing to whatever sprockets we could find. You must remember that there were NO performance parts back then and I mean NONE. We worked with what we had. No kits, they were all 50cc. That is all we did. We did not even know that they had timing to adjust! I would adjust the points to start opening a hair earlier than tdc. Now about the pipe. After a while somebody started to make a chamber pipe called a Proto Pipe. It was a slip on but we used to cut the exhaust manifold about halfway under the engine and clamp it there so the chamber was upswept. It exited around the seat height and looked cool as hell. Now the moment you have all been waiting for. These were all verified numerous times. I had a Negrini. They are vastly underrated. The frame and suspension were vastly superior the the Maxi's. I was clocked at 58. My friend Howard had first gen one speed Newport. I clocked him at 65 more than once. My friend Richard's Maxi looked bone stock but exceeded 60. Another friend Dirty Donnie claimed 70 but was never verified. All told at least ten of us went 55-65 and we rode in packs and passed cars. Of course off the line they were slow with those gears but the power helped once you started moving. All of this is true.
This is why I do not understand why, with all of the performance parts available today, we have mopeds that have been tricked out not even reaching what we used to get to. Of course some are but with WAY more performance that we could only dream of.
PS I just picked up a clean 1978 Maxi 1,5 and am in the process of making it go as fast as I can get it to so you will probably see me around here. And I want to thank you all for the huge amount of information that you put up. It is very helpful!
  Who has the fastest Puch !Topic by: Lazaro Velunza Lazaro Velunza 07/04/03 09:28PM
  Re: Who has the fastest Puch !Re: Andrew Mason Andrew Mason 07/04/03 09:48PM
  Re: Who has the fastest Puch !Re: Jorge Munoz Jorge Munoz 07/04/03 10:12PM
  Re: Who has the fastest Puch !Re: Lazaro Velunza Lazaro Velunza 07/04/03 11:52PM
  Re: Who has the fastest Puch !Re: Tab Patterson Tab Patterson 07/05/03 12:08AM
  Re: Who has the fastest Puch !Re: Lazaro Velunza Lazaro Velunza 07/05/03 02:43AM
  Re: Who has the fastest Puch !Re: Tab Patterson Tab Patterson 07/05/03 01:48PM
  Re: Who has the fastest Puch !Re: Luke Evans Luke Evans 07/05/03 10:02PM
  Re: Who has the fastest Puch !Re: Jeffrey Strichart Jeffrey Strichart 09/15/19 03:58PM
  Re: Who has the fastest Puch !Re: Potr zebie Potr zebie 09/15/19 04:03PM
  Re: Who has the fastest Puch !Re: LL danktip LL danktip 09/17/19 10:49PM
  Re: Who has the fastest Puch !Re: Daniel '' Daniel '' 09/17/19 11:21PM
  Re: Who has the fastest Puch !Re: * * * * 09/17/19 11:54PM
  Re: Who has the fastest Puch !Re: Probably Fred Probably Fred 09/18/19 01:51AM
  Re: Who has the fastest Puch !Re: Thomas Peffer Thomas Peffer 09/15/19 09:22PM
  Re: Who has the fastest Puch !Re: Daniel '' Daniel '' 09/15/19 09:27PM
  Re: Who has the fastest Puch !Re: * * * * 09/15/19 11:44PM
  Re: Who has the fastest Puch !Re: alex . alex . 09/16/19 12:32AM
  Re: Who has the fastest Puch !Re: Daniel '' Daniel '' 09/16/19 01:36AM
  Re: Who has the fastest Puch !Re: alex . alex . 09/16/19 01:54AM
  Re: Who has the fastest Puch !Re: EH FCC of the QCB EH FCC of the QCB 09/16/19 12:11PM
  Re: Who has the fastest Puch !Re: * * * * 09/16/19 01:38AM
  Re: Who has the fastest Puch !Re: Stephen Keller Stephen Keller 09/16/19 01:40AM
  Re: Who has the fastest Puch !Re: Mr. Duncan Mr. Duncan 09/16/19 02:11PM
  Re: Who has the fastest Puch !Re: Probably Fred Probably Fred 09/16/19 02:58PM
  Re: Who has the fastest Puch !Re: Boot 2Thehead Boot 2Thehead 09/17/19 12:08AM
  Re: Who has the fastest Puch !Re: Probably Fred Probably Fred 09/17/19 02:25AM
  Re: Who has the fastest Puch !Re: Boot 2Thehead Boot 2Thehead 09/17/19 10:08AM
  Re: Who has the fastest Puch !Re: Graham Motzing Graham Motzing 09/17/19 04:35PM
  Re: Who has the fastest Puch !Re: dan henkleman dan henkleman 09/17/19 08:12AM
  Re: Who has the fastest Puch !Re: >>>taykoff [s2m] >>>taykoff [s2m] 09/17/19 09:51AM
  Re: Who has the fastest Puch !Re: mit mortso mit mortso 09/17/19 03:26PM
  Re: Who has the fastest Puch !Re: * * * * 09/17/19 11:11PM
  Re: Who has the fastest Puch !Re: Dirty30 Dillon Dirty30 Dillon 09/17/19 11:20PM
  Re: Who has the fastest Puch !Re: * * * * 09/17/19 11:52PM
  Re: Who has the fastest Puch !Re: Daniel '' Daniel '' 09/18/19 12:04AM
  Re: Who has the fastest Puch !Re: * * * * 09/18/19 12:44AM
  Re: Who has the fastest Puch !Re: Dirty30 Dillon Dirty30 Dillon 09/18/19 01:11PM
  Re: Who has the fastest Puch !Re: * * * * 09/18/19 02:36PM
  Re: Who has the fastest Puch !Re: Dirty30 Dillon Dirty30 Dillon 09/18/19 02:53PM
  Re: Who has the fastest Puch !Re: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 09/18/19 12:48AM
  Re: Who has the fastest Puch !Re: Saabsonettguy . Saabsonettguy . 09/18/19 01:54PM
  Re: Who has the fastest Puch !Re: mit mortso mit mortso 09/18/19 01:59PM
  Re: Who has the fastest Puch !Re: Dave Steele Dave Steele 09/18/19 03:20PM
  Re: Who has the fastest Puch !Re: Jarod V. Jarod V. 09/19/19 05:44PM
  Re: Who has the fastest Puch !Re: Probably Fred Probably Fred 09/19/19 07:18PM
  Re: Who has the fastest Puch !Re: P D P D 09/19/19 09:47PM
  Re: Who has the fastest Puch !Re: live ɘvil live ɘvil 09/19/19 11:25PM
  Re: Who has the fastest Puch !Re: * * * * 09/19/19 11:31PM
  Re: Who has the fastest Puch !Re: * * * * 09/19/19 08:48PM
  Re: Who has the fastest Puch !Re: Brick Bowen Brick Bowen 09/19/19 10:02PM
  Re: Who has the fastest Puch !Re: Douglas Binder Douglas Binder 09/27/19 02:16PM
  Re: Who has the fastest Puch !Re: el pollo el pollo 09/27/19 06:50PM
  Re: Who has the fastest Puch !Re: el pollo el pollo 09/27/19 06:52PM
  Re: Who has the fastest Puch !Re: Scottie Hartpence Scottie Hartpence 01/10/21 08:30PM
  Re: Who has the fastest Puch !Re: Nile Muti Nile Muti 01/11/21 01:30AM
