Re: Who has the fastest Puch !
Probably Fred /
The Polini and Gila kit magnum and maxi bikes I have can low 60s mph easy with big pipe, higher rpm setup but I set them up to go slower 55-60 mph basically all were built/setup 11-12 or longer years ago,
I also had a mild rpm build small port metra 80, 19mm PHBG maxi that did 57mph that ran great for several years before I sold the bike,
All engines have original stock asbestos clutches (some with springs/mods done to them) pretty much (well I’ve changed a few), stock bells and gears inside and of course all engines have maintenance done to them,
Power Down Low and a Low RPM cap/limit you can still have a reasonably fast but very reliable bike, just 5-7 miles slower with around 1,500-2,000 less rpm increases the life dramatically on a puch engine and no extra expensive parts needed like HPI, straight cut gears, super clutches, special clutch bells, pull starts etc.
When I feel like having a speed run I’ll take the estoril/low rpm pipes off and put on a Motomatic, MLM pipe or other big pipe on (needle crank engines only), do a bit of tuning and go for a speed run:
But when I do go for a fast 10 mi run It feels like something wants to blow/is ready to blow, though it don’t,
  Who has the fastest Puch !Topic by: Lazaro Velunza Lazaro Velunza 07/04/03 09:28PM
  Re: Who has the fastest Puch !Re: Andrew Mason Andrew Mason 07/04/03 09:48PM
  Re: Who has the fastest Puch !Re: Jorge Munoz Jorge Munoz 07/04/03 10:12PM
  Re: Who has the fastest Puch !Re: Lazaro Velunza Lazaro Velunza 07/04/03 11:52PM
  Re: Who has the fastest Puch !Re: Tab Patterson Tab Patterson 07/05/03 12:08AM
  Re: Who has the fastest Puch !Re: Lazaro Velunza Lazaro Velunza 07/05/03 02:43AM
  Re: Who has the fastest Puch !Re: Tab Patterson Tab Patterson 07/05/03 01:48PM
  Re: Who has the fastest Puch !Re: Luke Evans Luke Evans 07/05/03 10:02PM
  Re: Who has the fastest Puch !Re: Jeffrey Strichart Jeffrey Strichart 09/15/19 03:58PM
  Re: Who has the fastest Puch !Re: Potr zebie Potr zebie 09/15/19 04:03PM
  Re: Who has the fastest Puch !Re: LL danktip LL danktip 09/17/19 10:49PM
  Re: Who has the fastest Puch !Re: Daniel '' Daniel '' 09/17/19 11:21PM
  Re: Who has the fastest Puch !Re: * * * * 09/17/19 11:54PM
  Re: Who has the fastest Puch !Re: Probably Fred Probably Fred 09/18/19 01:51AM
  Re: Who has the fastest Puch !Re: Thomas Peffer Thomas Peffer 09/15/19 09:22PM
  Re: Who has the fastest Puch !Re: Daniel '' Daniel '' 09/15/19 09:27PM
  Re: Who has the fastest Puch !Re: * * * * 09/15/19 11:44PM
  Re: Who has the fastest Puch !Re: alex . alex . 09/16/19 12:32AM
  Re: Who has the fastest Puch !Re: Daniel '' Daniel '' 09/16/19 01:36AM
  Re: Who has the fastest Puch !Re: alex . alex . 09/16/19 01:54AM
  Re: Who has the fastest Puch !Re: EH FCC of the QCB EH FCC of the QCB 09/16/19 12:11PM
  Re: Who has the fastest Puch !Re: * * * * 09/16/19 01:38AM
  Re: Who has the fastest Puch !Re: Stephen Keller Stephen Keller 09/16/19 01:40AM
  Re: Who has the fastest Puch !Re: Mr. Duncan Mr. Duncan 09/16/19 02:11PM
  Re: Who has the fastest Puch !Re: Probably Fred Probably Fred 09/16/19 02:58PM
  Re: Who has the fastest Puch !Re: Boot 2Thehead Boot 2Thehead 09/17/19 12:08AM
  Re: Who has the fastest Puch !Re: Probably Fred Probably Fred 09/17/19 02:25AM
  Re: Who has the fastest Puch !Re: Boot 2Thehead Boot 2Thehead 09/17/19 10:08AM
  Re: Who has the fastest Puch !Re: Graham Motzing Graham Motzing 09/17/19 04:35PM
  Re: Who has the fastest Puch !Re: dan henkleman dan henkleman 09/17/19 08:12AM
  Re: Who has the fastest Puch !Re: >>>taykoff [s2m] >>>taykoff [s2m] 09/17/19 09:51AM
  Re: Who has the fastest Puch !Re: mit mortso mit mortso 09/17/19 03:26PM
  Re: Who has the fastest Puch !Re: * * * * 09/17/19 11:11PM
  Re: Who has the fastest Puch !Re: Dirty30 Dillon Dirty30 Dillon 09/17/19 11:20PM
  Re: Who has the fastest Puch !Re: * * * * 09/17/19 11:52PM
  Re: Who has the fastest Puch !Re: Daniel '' Daniel '' 09/18/19 12:04AM
  Re: Who has the fastest Puch !Re: * * * * 09/18/19 12:44AM
  Re: Who has the fastest Puch !Re: Dirty30 Dillon Dirty30 Dillon 09/18/19 01:11PM
  Re: Who has the fastest Puch !Re: * * * * 09/18/19 02:36PM
  Re: Who has the fastest Puch !Re: Dirty30 Dillon Dirty30 Dillon 09/18/19 02:53PM
  Re: Who has the fastest Puch !Re: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 09/18/19 12:48AM
  Re: Who has the fastest Puch !Re: Saabsonettguy . Saabsonettguy . 09/18/19 01:54PM
  Re: Who has the fastest Puch !Re: mit mortso mit mortso 09/18/19 01:59PM
  Re: Who has the fastest Puch !Re: Dave Steele Dave Steele 09/18/19 03:20PM
  Re: Who has the fastest Puch !Re: Jarod V. Jarod V. 09/19/19 05:44PM
  Re: Who has the fastest Puch !Re: Probably Fred Probably Fred 09/19/19 07:18PM
  Re: Who has the fastest Puch !Re: P D P D 09/19/19 09:47PM
  Re: Who has the fastest Puch !Re: live ɘvil live ɘvil 09/19/19 11:25PM
  Re: Who has the fastest Puch !Re: * * * * 09/19/19 11:31PM
  Re: Who has the fastest Puch !Re: * * * * 09/19/19 08:48PM
  Re: Who has the fastest Puch !Re: Brick Bowen Brick Bowen 09/19/19 10:02PM
  Re: Who has the fastest Puch !Re: Douglas Binder Douglas Binder 09/27/19 02:16PM
  Re: Who has the fastest Puch !Re: el pollo el pollo 09/27/19 06:50PM
  Re: Who has the fastest Puch !Re: el pollo el pollo 09/27/19 06:52PM
  Re: Who has the fastest Puch !Re: Scottie Hartpence Scottie Hartpence 01/10/21 08:30PM
  Re: Who has the fastest Puch !Re: Nile Muti Nile Muti 01/11/21 01:30AM
