The side effects take a while to wear off. You all stumble around in a daze down the long corridor bridge in the pit of blackness....
The bugs hovering around you are biting and stinging you easily since your daze makes you all easy targets.
You come across a closed door which you all make your way through to get out of the pestering big onslaught. You all lose 3 hit points from the stings.
Upon passing the door you are all extremely confused. This is what you see:
An astral plane of poppy fields.... of flowers stretching forever.
You all do a roll call to see who remains after the 3 months of time standing still, and the bug onslaught. Your party originated with:
Deezy, Spoo, Em, Sir Cliff, Albo, Tracy, Robert, Will, Trevor, Stever, Ryanr, Serene, Gabe. Some are lost in time. Deezy is dead.
When you all figure that out, you travel into the field of poppies...
Popping out of the poppies you encounter 3 giant creatures, each has bronzed skin, frosted razor sharp hair tips (1d6 damage) and towers over you all at 20 feet. You immediately recognize them as 2 Garyflower Undertrolls and a Gary Flowers UberLifanTroll! The UberLifan troll has surprized you adventures in your dazed state and attacked with a Mod spell!
Sir Cliff's legs are now on Spoo's torso, and vice versa. Tracy's ambition is now in Roberts heart. Em's sparkplug flail now uses lifan clutches, Albo switches to windex and trades his literacy with Stever. All is confused.
The Undertrolls are bending over and preparing to do a Frosted Tip charge upon the party. The Uberlifantroll is preparing a spell of some sorts.
How do you proceed?
