> Nick Haber Wrote:
> I found the default view
> way too hard to use and just never used the site because of it.
FYI: the site was changed a while ago so that flat view is now the default for new users. In fact threaded view is no longer an option you can select site wide, it must be selected for each thread individually. You might not have realize that because you were already using flat view. I heard the feedback and changed it so the flat view is the primary view now.
Here’s a post from last September with detailed information about this change: https://www.mopedarmy.com/forums/read.php?1,4221202
