Re: circuit boards
Aaron Blair /
another hobby of mine is electronics. roff is right here, its called point to point wiring and was used on radios, amps, pretty much everything up until the late 50's and somewhat later. very robust and the easiest to service...pull a part, j-hook the new one and solder...ur done..
the etching chemicals for photo-resist boards really arent that bad. i think its just ferric chloride right???..i mean i develop my own b/w film and i dont treat boards any differently. get it on your hand. washy washy...all is good
for most simple things i just grab a copper clad fiberglass board blank, lay out the circuit and remove the copper around the traces with a dremel..if ur doing through hole, a tiny pin vice works wonders..u can use tiny copper rivets for dual sided boards as well.
if its a simple curcuit, id either dead bug it or hand mill a board for mid size surface mount discreet components by hand.
actually...fuck it, just grab a proto board and make your traces with solder.
  circuit boardsTopic by: kenny s kenny s 04/11/19 06:31PM
  Re: circuit boardsRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/12/19 03:31AM
  Re: circuit boardsRe: Overpriced Parts Overpriced Parts 04/12/19 03:54AM
  Re: circuit boardsRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/12/19 09:19AM
  Re: circuit boardsRe: Aaron Blair Aaron Blair 04/12/19 07:54AM
  Re: circuit boardsRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 04/12/19 09:02PM
  Re: circuit boardsRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/12/19 10:04PM
  Re: circuit boardsRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 04/12/19 09:06PM
  Re: circuit boardsRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 04/13/19 02:44PM
  Re: circuit boardsRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/13/19 09:05PM
  Re: circuit boardsRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 04/14/19 01:26AM
  Re: circuit boardsRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/16/19 06:20AM
  Re: circuit boardsRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 04/16/19 06:51AM
  Re: circuit boardsRe: Douglas Binder Douglas Binder 04/16/19 08:38AM
  Re: circuit boardsRe: Born to be WillD Born to be WillD 04/16/19 10:10AM
  Re: circuit boardsRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 04/16/19 03:34PM
  Re: circuit boardsRe: ERIC from Idaho! ERIC from Idaho! 04/16/19 05:45PM
  Re: circuit boardsRe: Ungapped rings to bind them all Ungapped rings to bind them all 04/18/19 09:06PM
  Re: circuit boardsRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/18/19 09:17PM
  Re: circuit boardsRe: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 04/19/19 12:44AM
  Re: circuit boardsRe: Aaron Blair Aaron Blair 04/19/19 02:01AM
  Re: circuit boardsRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/19/19 04:43AM
