Re: Options for a flat slide on Chinese scooter
Born to be WillD /
They sell whole "big bore kits" (kinda hate that term cuz it so plainly reeks of scooter tunerz) but u can get those for under 100 bucks, I got one free for helping a guy install one on his (he bought 2, gave me the spare)
The carb was fine. Actually I shouldn't say that, the choke never worked and the cable would hang up on shit all the time. But the diaphragm aspect was never trouble, had good throttle response. As for the fuel petcock thing? You can get ones that are direct flow, just swapping the petcock and plugging the bung on the intake. Actually most all of the several China 4t scooters I've helped people fix most 9ften it's that vacuum line that had failed. Simple fix, worth it to avoid entirely. But it does work with whatever carb you put on. Ideally a 4 stroke carb, or properly setup for 4 strokes, some moped ones like phbg require different atomizers for example. It is as mentioned a different throttle style so you need a new throttle cable and its gotta be extra long to go all the way back under the floorboards etc. A bicycle derailleur cable and housing with a mini knarp would work too
  Options for a flat slide on Chinese scooterTopic by: Eric Davenport Eric Davenport 04/30/19 10:00PM
  Re: Options for a flat slide on Chinese scooterRe: Don Ohio Don Ohio 04/30/19 10:04PM
  Re: Options for a flat slide on Chinese scooterRe: Eric Davenport Eric Davenport 04/30/19 11:11PM
  Re: Options for a flat slide on Chinese scooterRe: A Zed A Zed 05/01/19 12:17AM
  Re: Options for a flat slide on Chinese scooterRe: Don Ohio Don Ohio 05/01/19 12:22AM
  Re: Options for a flat slide on Chinese scooterRe: Don Ohio Don Ohio 05/01/19 12:28AM
  Re: Options for a flat slide on Chinese scooterRe: A Zed A Zed 05/01/19 12:39AM
  Re: Options for a flat slide on Chinese scooterRe: Aaron Blair Aaron Blair 05/01/19 12:37AM
  Re: Options for a flat slide on Chinese scooterRe: Don Ohio Don Ohio 05/01/19 12:53AM
  Re: Options for a flat slide on Chinese scooterRe: A Zed A Zed 05/01/19 12:57AM
  Re: Options for a flat slide on Chinese scooterRe: Eric Davenport Eric Davenport 05/01/19 04:55PM
  Re: Options for a flat slide on Chinese scooterRe: Stephen Simmons Stephen Simmons 05/01/19 06:32PM
  Re: Options for a flat slide on Chinese scooterRe: Don Ohio Don Ohio 05/01/19 11:29PM
  Re: Options for a flat slide on Chinese scooterRe: Stephen Simmons Stephen Simmons 05/02/19 02:23AM
  Re: Options for a flat slide on Chinese scooterRe: Rick Bergsma Rick Bergsma 05/01/19 08:09PM
  Re: Options for a flat slide on Chinese scooterRe: Don Ohio Don Ohio 05/02/19 02:16PM
  Re: Options for a flat slide on Chinese scooterRe: Dirty30 Dillon Dirty30 Dillon 05/02/19 05:10PM
  Re: Options for a flat slide on Chinese scooterRe: Don Ohio Don Ohio 05/02/19 06:03PM
  Re: Options for a flat slide on Chinese scooterRe: Rick Bergsma Rick Bergsma 05/03/19 08:35AM
  Re: Options for a flat slide on Chinese scooterRe: A Zed A Zed 05/03/19 08:52AM
  Re: Options for a flat slide on Chinese scooterRe: Don Ohio Don Ohio 05/03/19 03:16PM
  Re: Options for a flat slide on Chinese scooterRe: Stephen Keller Stephen Keller 05/03/19 10:12PM
  Re: Options for a flat slide on Chinese scooterRe: Dirty30 Dillon Dirty30 Dillon 05/03/19 03:33PM
  Re: Options for a flat slide on Chinese scooterRe: A Zed A Zed 05/03/19 03:40PM
  Re: Options for a flat slide on Chinese scooterRe: Don Ohio Don Ohio 05/03/19 03:42PM
  Re: Options for a flat slide on Chinese scooterRe: Born to be WillD Born to be WillD 05/02/19 09:59PM
  Re: Options for a flat slide on Chinese scooterRe: Eric Davenport Eric Davenport 05/03/19 01:04PM
  Re: Options for a flat slide on Chinese scooterRe: Born to be WillD Born to be WillD 05/05/19 10:01AM
  Re: Options for a flat slide on Chinese scooterRe: Don Ohio Don Ohio 05/03/19 03:39PM
  Re: Options for a flat slide on Chinese scooterRe: Dirty30 Dillon Dirty30 Dillon 05/03/19 05:07PM
  Re: Options for a flat slide on Chinese scooterRe: Don Ohio Don Ohio 05/03/19 11:34PM
  Re: Options for a flat slide on Chinese scooterRe: Dirty30 Dillon Dirty30 Dillon 05/04/19 08:32PM
  Re: Options for a flat slide on Chinese scooterRe: Eric Davenport Eric Davenport 05/03/19 04:02PM
  Re: Options for a flat slide on Chinese scooterRe: Stephen Simmons Stephen Simmons 05/03/19 04:13PM
