Re: Batshit crazy idea
Good luck with that 6spd. I broke a few of them when i used to race lawnmowers back in the late 90’s. The Peerless 3spd’s (600 series?) with the sideways H pattern are bomb proof if you can find one with a full set of needle bearings.
I used to run a 6” pulley on the engine, and a 2-1/2” on top of a 3” on the trans. I rigged up a derailleur at the trans to switch between the two pulleys that was actuated by cable attached to a lever that got pulled when i pushed the clutch all the way to the floor. The derailleur would toggle between the two pulleys with each push of the clutch.
I copied the mechanism similar to that of a push button switch that latches down in the on position and releases up in the off position to hold the derailleur in its 2 positions.
I was running on a 1/3 mile clay oval track breaking 60+mph in the straights. Needing to downshift in the turns to keep the power up, 2nd gear of the 3spd trans was just too low.
The derailleur setup gave me a perfect ratio in between 2nd and 3rd, and it made “shifting” a breeze. Kick the clutch coming into the turns, and kick it again on the way out. I could keep both hands on the wheel, and believe me, i needed it. That track was rough, especially with no suspension.
A few crappy pics of it.
  Batshit crazy ideaTopic by: Robert Emery Robert Emery 06/10/19 12:31AM
  Re: Batshit crazy ideaRe: Stephen Keller Stephen Keller 06/10/19 12:36AM
  Re: Batshit crazy ideaRe: Robert Emery Robert Emery 06/10/19 12:46AM
  Re: Batshit crazy ideaRe: Stephen Keller Stephen Keller 06/10/19 12:57AM
  Re: Batshit crazy ideaRe: Jimmy Cincinnati Jimmy Cincinnati 06/10/19 07:23AM
  Re: Batshit crazy ideaRe: Saabsonettguy . Saabsonettguy . 06/10/19 09:21AM
  Re: Batshit crazy ideaRe: Seth B Seth B 06/10/19 10:47AM
  Re: Batshit crazy ideaRe: ♣Slew Foot♣ ♣Slew Foot♣ 06/17/19 10:42AM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/02/19 12:08AM
  Re: Batshit crazy ideaRe: Born to be WillD Born to be WillD 07/02/19 11:29AM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/06/19 01:54AM
  Re: Batshit crazy ideaRe: Born to be WillD Born to be WillD 07/09/19 08:51AM
  Re: Batshit crazy ideaRe: Potr zebie Potr zebie 07/02/19 09:09AM
  Re: Batshit crazy ideaRe: jayson sumpter jayson sumpter 07/02/19 09:22AM
  Re: Batshit crazy ideaRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/06/19 05:56AM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/06/19 12:27PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/07/19 12:05AM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/08/19 06:26PM
  Re: Batshit crazy ideaRe: Overpriced Parts Overpriced Parts 07/08/19 07:25PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/08/19 09:49PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/08/19 09:58PM
  Re: Batshit crazy ideaRe: Stephen Keller Stephen Keller 07/09/19 01:08AM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/09/19 01:46AM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/09/19 01:47AM
  Re: Batshit crazy ideaRe: live ɘvil live ɘvil 07/09/19 03:13AM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/09/19 03:22AM
  Re: Batshit crazy ideaRe: Saabsonettguy . Saabsonettguy . 07/09/19 01:37PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/10/19 02:38PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/10/19 02:45PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/10/19 02:47PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/10/19 03:06PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/11/19 11:32AM
  Re: Batshit crazy ideaRe: Graham Motzing Graham Motzing 07/11/19 12:43PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/11/19 01:06PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/11/19 01:12PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/11/19 01:17PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/11/19 01:25PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/11/19 01:34PM
  Re: Batshit crazy ideaRe: Born to be WillD Born to be WillD 07/12/19 03:23PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/12/19 06:23PM
  Re: Batshit crazy ideaRe: live ɘvil live ɘvil 07/12/19 06:54PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/12/19 07:00PM
  Re: Batshit crazy ideaRe: live ɘvil live ɘvil 07/12/19 07:20PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/13/19 01:43PM
  Re: Batshit crazy ideaRe: live ɘvil live ɘvil 07/13/19 02:42PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/13/19 07:49PM
  Re: Batshit crazy ideaRe: ♣Slew Foot♣ ♣Slew Foot♣ 07/14/19 06:12AM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/25/19 11:40PM
  Re: Batshit crazy ideaRe: Stephen Keller Stephen Keller 08/03/19 10:12PM
  Re: Batshit crazy ideaRe: Jimmy Cincinnati Jimmy Cincinnati 07/26/19 07:58AM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/27/19 12:10PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 07/31/19 08:45PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/01/19 05:52AM
  Re: Batshit crazy ideaRe: Graham Motzing Graham Motzing 08/01/19 05:37PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/05/19 10:45AM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/06/19 10:48AM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/06/19 12:10PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/06/19 12:22PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/06/19 06:31PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/06/19 07:57PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/07/19 05:14PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/08/19 03:26AM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/08/19 02:28PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/08/19 03:54PM
  Re: Batshit crazy ideaRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/08/19 06:49PM
  Re: Batshit crazy ideaRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/08/19 06:50PM
  Re: Batshit crazy ideaRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/08/19 07:05PM
  Re: Batshit crazy ideaRe: Robert Emery Robert Emery 08/12/19 01:44AM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/15/19 10:27PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/16/19 04:55PM
  Re: Batshit crazy ideaRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/16/19 05:51PM
  Re: Batshit crazy ideaRe: jayson sumpter jayson sumpter 08/17/19 10:35AM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/18/19 09:33PM
  Re: Batshit crazy ideaRe: Daniel '' Daniel '' 08/18/19 10:12PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/18/19 10:59PM
  Re: Batshit crazy ideaRe: Ada Dictome Ada Dictome 08/20/19 09:07AM
  Re: Batshit crazy ideaRe: jayson sumpter jayson sumpter 08/20/19 09:22AM
