Re: Batshit crazy idea
Anonymous User /
scootertrash
The 6 speed transmission is tack welded to the snapper. The pulleys don’t line up so I’m going to have to redo the pulley on the engine to sit lower. The ratio is 1:2. 1 turn of the engine is 2 turns. It was about 4:1, a 3” engine shaft pulley to an 8”, this is way different.
This guy is running 1:1 with the same transaxle.
Anonymous User /
scootertrash
Anonymous User /
scootertrash
One of the guys took it for a spin. It’s fast enuff! :) now I’m connecting the 1st-6 gear shifter to a pedal.
The tiny transmission brake lever on the other side. Little brake rotor was glowing red last night
Anonymous User /
scootertrash
Foot shifter, it works fine.
Good luck with that 6spd. I broke a few of them when i used to race lawnmowers back in the late 90’s. The Peerless 3spd’s (600 series?) with the sideways H pattern are bomb proof if you can find one with a full set of needle bearings.
I used to run a 6” pulley on the engine, and a 2-1/2” on top of a 3” on the trans. I rigged up a derailleur at the trans to switch between the two pulleys that was actuated by cable attached to a lever that got pulled when i pushed the clutch all the way to the floor. The derailleur would toggle between the two pulleys with each push of the clutch.
I copied the mechanism similar to that of a push button switch that latches down in the on position and releases up in the off position to hold the derailleur in its 2 positions.
I was running on a 1/3 mile clay oval track breaking 60+mph in the straights. Needing to downshift in the turns to keep the power up, 2nd gear of the 3spd trans was just too low.
The derailleur setup gave me a perfect ratio in between 2nd and 3rd, and it made “shifting” a breeze. Kick the clutch coming into the turns, and kick it again on the way out. I could keep both hands on the wheel, and believe me, i needed it. That track was rough, especially with no suspension.
A few crappy pics of it.
Ran a tach and temp gauge, oil cooler and filter. Warmed over 11hp Briggs with a 10hp head, 91octane, accelerator pedal on the right eventually got replaced with a thumb throttle so i could keep my foot flat on the running board to help keep my ass planted on the seat in the turns.
Took 1st place trophy against 6 other mowers on day. Two of them were 18hp twins. :)(edited)
P.S. A brand new belt was good for 8, maybe 10 laps. Lol
Had my share of DNF’s because of a damn belt.
I honestly completely forgot about my own post that and I forgot my password and have been busy building and troubleshooting my bastard vespa and work as been hell on me lately. I didnt think this would blow up at all haha.
Anonymous User /
scootertrash
Range Rover 19z on the power wheels ha!
Anonymous User /
scootertrash
I hit slo-mo on accident, good for the ears! WhaT!!
Now THAT was fucking awesome.
Yea, wooow ha ha
Anonymous User /
scootertrash
The other engine still works.
Wocket powerd
Did the crank snap? Or just lose a nut?
Anonymous User /
scootertrash
The crank snapped off the rear one. Rebuild repeat. it had a wired end for end belt for tension, against the swing spring thing. The fuel sprays out the other side seal when it goes.
Anonymous User /
scootertrash
Ho dose ?
Holy hell, @dwayne hoster are you seeing this?
