Re: Are Mercedes Really that Expensive?
Norris Hall /
Can't believe this thread is still going. Now that it has been hopelessly 'jacked I'll jump in again with $.02 on the SEL for the benefit of Mr Keller. Nice color but I can see the rust creeping out on the rear wheel well. Looks decent right now but won't for long especially in your neck of the woods. If you are into the look of that chassis then I would suggest you find a 300SD. You get the exact same car but with much much less potential for the lightening of the pocketbook that is inevitable with these cars in general and especially so with the older 450/560 cars. Unless you are anti diesel the SD will be exponentially more reliable and less costly but you do have to make sure it is healthy compression wise out your way. Wouldn't want it for a daily in February out there. I own and work on quite a few of these cars, the gassers and diesels. The best you can hope for as far as start-ability goes in the winter with the diesels is around zero degrees without being plugged in and you better have a very healthy battery, good connections and all glowplugs functional as well as good compression and 5w40 synthetic to start at those temps without the block heater.
  Are Mercedes Really that Expensive?Topic by: Josiah Radebaugh Josiah Radebaugh 08/05/19 04:51PM
  Re: Are Mercedes Really that Expensive?Re: Jim Jones Jim Jones 08/05/19 04:57PM
  Re: Are Mercedes Really that Expensive?Re: Norris Hall Norris Hall 08/05/19 05:07PM
  Re: Are Mercedes Really that Expensive?Re: Norris Hall Norris Hall 08/05/19 05:19PM
  Re: Are Mercedes Really that Expensive?Re: Daniel '' Daniel '' 08/05/19 05:39PM
  Re: Are Mercedes Really that Expensive?Re: Josiah Radebaugh Josiah Radebaugh 08/05/19 06:02PM
  Re: Are Mercedes Really that Expensive?Re: Daniel '' Daniel '' 08/05/19 06:47PM
  Re: Are Mercedes Really that Expensive?Re: Norris Hall Norris Hall 08/05/19 06:30PM
  Re: Are Mercedes Really that Expensive?Re: Josiah Radebaugh Josiah Radebaugh 08/05/19 06:50PM
  Re: Are Mercedes Really that Expensive?Re: Bob Naske Bob Naske 08/05/19 06:44PM
  Re: Are Mercedes Really that Expensive?Re: Barry (Bob) Brown Barry (Bob) Brown 08/05/19 06:45PM
  Re: Are Mercedes Really that Expensive?Re: Norris Hall Norris Hall 08/05/19 06:50PM
  Re: Are Mercedes Really that Expensive?Re: Daniel '' Daniel '' 08/06/19 04:49PM
  Re: Are Mercedes Really that Expensive?Re: Josiah Radebaugh Josiah Radebaugh 08/06/19 09:56PM
  Re: Are Mercedes Really that Expensive?Re: live ɘvil live ɘvil 08/07/19 11:14AM
  Re: Are Mercedes Really that Expensive?Re: Josiah Radebaugh Josiah Radebaugh 08/07/19 11:00PM
  Re: Are Mercedes Really that Expensive?Re: Dirty30 Dillon Dirty30 Dillon 08/15/19 03:40PM
  Re: Are Mercedes Really that Expensive?Re: Born to be WillD Born to be WillD 08/08/19 10:58AM
  Re: Are Mercedes Really that Expensive?Re: Norris Hall Norris Hall 08/05/19 07:09PM
  Re: Are Mercedes Really that Expensive?Re: Norris Hall Norris Hall 08/05/19 07:11PM
  Re: Are Mercedes Really that Expensive?Re: Norris Hall Norris Hall 08/05/19 07:19PM
  Re: Are Mercedes Really that Expensive?Re: Stephen Keller Stephen Keller 08/05/19 10:26PM
  Re: Are Mercedes Really that Expensive?Re: A Zed A Zed 08/06/19 01:29AM
  Re: Are Mercedes Really that Expensive?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/06/19 07:12AM
  Re: Are Mercedes Really that Expensive?Re: live ɘvil live ɘvil 08/06/19 12:45PM
  Re: Are Mercedes Really that Expensive?Re: Jim Jones Jim Jones 08/06/19 07:43AM
  Re: Are Mercedes Really that Expensive?Re: Aaron Blair Aaron Blair 08/06/19 08:49AM
  Re: Are Mercedes Really that Expensive?Re: Jimmy Cincinnati Jimmy Cincinnati 08/06/19 09:44AM
  Re: Are Mercedes Really that Expensive?Re: Don Ohio Don Ohio 08/06/19 11:59AM
  Re: Are Mercedes Really that Expensive?Re: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 08/06/19 09:53PM
  Re: Are Mercedes Really that Expensive?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/06/19 10:46PM
  Re: Are Mercedes Really that Expensive?Re: Stephen Keller Stephen Keller 08/11/19 07:12PM
  Re: Are Mercedes Really that Expensive?Re: Josiah Radebaugh Josiah Radebaugh 08/11/19 11:24PM
  Re: Are Mercedes Really that Expensive?Re: ♣Slew Foot♣ ♣Slew Foot♣ 08/07/19 01:55AM
  Re: Are Mercedes Really that Expensive?Re: __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__ 08/07/19 10:11AM
  Re: Are Mercedes Really that Expensive?Re: Chris Szuba Chris Szuba 08/07/19 07:57AM
  Re: Are Mercedes Really that Expensive?Re: Norris Hall Norris Hall 08/08/19 12:02AM
  Re: Are Mercedes Really that Expensive?Re: Norris Hall Norris Hall 08/08/19 12:15AM
  Re: Are Mercedes Really that Expensive?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/08/19 06:17AM
  Re: Are Mercedes Really that Expensive?Re: punkrock randy punkrock randy 08/11/19 10:18AM
  Re: Are Mercedes Really that Expensive?Re: ♣Slew Foot♣ ♣Slew Foot♣ 08/15/19 03:43AM
  Re: Are Mercedes Really that Expensive?Re: A Zed A Zed 08/15/19 09:09AM
  Re: Are Mercedes Really that Expensive?Re: ♣Slew Foot♣ ♣Slew Foot♣ 08/18/19 11:17PM
  Re: Are Mercedes Really that Expensive?Re: Stephen Keller Stephen Keller 08/18/19 11:59PM
  Re: Are Mercedes Really that Expensive?Re: ♣Slew Foot♣ ♣Slew Foot♣ 08/09/19 10:02AM
  Re: Are Mercedes Really that Expensive?Re: A Zed A Zed 08/09/19 11:19AM
  Re: Are Mercedes Really that Expensive?Re: Stephen Keller Stephen Keller 08/09/19 12:13PM
  Re: Are Mercedes Really that Expensive?Re: Born to be WillD Born to be WillD 08/09/19 04:23PM
  Re: Are Mercedes Really that Expensive?Re: Don Ohio Don Ohio 08/11/19 11:46AM
  Re: Are Mercedes Really that Expensive?Re: A Zed A Zed 08/11/19 03:23PM
  Re: Are Mercedes Really that Expensive?Re: Don Ohio Don Ohio 08/12/19 12:49AM
  Re: Are Mercedes Really that Expensive?Re: A Zed A Zed 08/12/19 04:16AM
  Re: Are Mercedes Really that Expensive?Re: Jimmy Cincinnati Jimmy Cincinnati 08/12/19 07:49AM
  Re: Are Mercedes Really that Expensive?Re: Born to be WillD Born to be WillD 08/12/19 10:25AM
  Re: Are Mercedes Really that Expensive?Re: Don Ohio Don Ohio 08/12/19 10:30AM
  Re: Are Mercedes Really that Expensive?Re: A Zed A Zed 08/16/19 03:29PM
  Re: Are Mercedes Really that Expensive?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/16/19 05:57PM
  Re: Are Mercedes Really that Expensive?Re: Stephen Keller Stephen Keller 08/16/19 07:06PM
  Re: Are Mercedes Really that Expensive?Re: Stephen Keller Stephen Keller 08/16/19 03:23PM
  Re: Are Mercedes Really that Expensive?Re: Jimmy Cincinnati Jimmy Cincinnati 08/19/19 07:53AM
  Re: Are Mercedes Really that Expensive?Re: Stephen Keller Stephen Keller 08/19/19 03:38PM
  Re: Are Mercedes Really that Expensive?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/19/19 06:18PM
  Re: Are Mercedes Really that Expensive?Re: Stephen Keller Stephen Keller 08/19/19 07:00PM
  Re: Are Mercedes Really that Expensive?Re: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 08/19/19 09:28PM
  Re: Are Mercedes Really that Expensive?Re: Stephen Keller Stephen Keller 08/20/19 01:01AM
  Re: Are Mercedes Really that Expensive?Re: Norris Hall Norris Hall 08/20/19 01:46AM
  Re: Are Mercedes Really that Expensive?Re: Stephen Keller Stephen Keller 08/20/19 04:06AM
  Re: Are Mercedes Really that Expensive?Re: Norris Hall Norris Hall 08/20/19 05:13AM
  Re: Are Mercedes Really that Expensive?Re: Norris Hall Norris Hall 08/20/19 12:29PM
  Re: Are Mercedes Really that Expensive?Re: Josiah Radebaugh Josiah Radebaugh 08/20/19 11:25PM
  Re: Are Mercedes Really that Expensive?Re: Daniel '' Daniel '' 08/21/19 12:10AM
  Re: Are Mercedes Really that Expensive?Re: jayson sumpter jayson sumpter 08/21/19 07:57AM
  Re: Are Mercedes Really that Expensive?Re: live ɘvil live ɘvil 08/21/19 09:01AM
  Re: Are Mercedes Really that Expensive?Re: Aaron Blair Aaron Blair 08/21/19 09:08AM
  Re: Are Mercedes Really that Expensive?Re: live ɘvil live ɘvil 08/21/19 09:25AM
  Re: Are Mercedes Really that Expensive?Re: ♣Slew Foot♣ ♣Slew Foot♣ 08/21/19 11:38PM
  Re: Are Mercedes Really that Expensive?Re: Stephen Keller Stephen Keller 08/22/19 01:05AM
  Re: Are Mercedes Really that Expensive?Re: ♣Slew Foot♣ ♣Slew Foot♣ 08/22/19 02:35AM
  Re: Are Mercedes Really that Expensive?Re: Jimmy Cincinnati Jimmy Cincinnati 08/20/19 01:57PM
  Re: Are Mercedes Really that Expensive?Re: live ɘvil live ɘvil 08/20/19 08:07PM
  Re: Are Mercedes Really that Expensive?Re: Stephen Keller Stephen Keller 08/21/19 01:07AM
  Re: Are Mercedes Really that Expensive?Re: live ɘvil live ɘvil 08/21/19 01:20AM
  Re: Are Mercedes Really that Expensive?Re: Stephen Keller Stephen Keller 08/20/19 02:41PM
