I made a steady cam for experimenting with video, weird effect on corners, accelerating and braking, does nothing noticeable to get rid of jello screen from vibrations. Camera on a wood stick across the seat with butt pressure on the stick damps the vibration quite nicely if you have a cheapo knockoff camera.
> ..... poop Wrote:
> you could try to use a handheld dslr steady mount
> the camera sits on the mount and gimbel and has a piece that curves
> outwards and down with a counter-weight at the bottom
> remove the handle grip and replace it with a bolted on piece of wood, or
> clamp it to a c-stand arm and onto your bike
> **the pic is of a super cheap consumer version, not sure if this
> particular model is smooth enough. in the end it all really comes down
> to how much you wanna pay.
> Smooth = Expensive**
