You're gonna need a couple pallets.
Crate up each on the pallets. Look for accommodating sizes behind stores and warehoses. Ask before tsking, but odd sized pallets are generally thrown away.
You gonna need a shipper with a lift gate truck to pick up at anything less than a dock.
Almost forgot...
A typical pallet jack (electric or manual) will have problems lifting odd size pallets because of fork wheel spacing. So before you start, knock the bottom cross boards off FIRST.
Look for hardwood they will feel heavier. You can always add wood to the upper deck. (edited)
