Re: Need help to ID this HUGE mikuni
> Saabsonettguy . Wrote:
> It looks like it might be a Generic version of the stock carb. Like the
> cheap ones you buy on ebay. The biggest difference I see is that it has
> a manual choke rather than the stock electric choke. i would measure the
> diameter and thread of the jets and see if mikuni jets are the same.
I didnt think to check, but now that you mention it I do recall the main jet being about the same size as 5mm dellorto.
This carb is much bigger than I think the stock carb was (dont have the stock carb), somebody had cut a hole in the plastic fender so the bowl would fit.
